2001 Toyota Sequoia
2001 TOYOTA SEQUOIA
110,000 MILES • V8 • 4WD • AUTOMATIC
CREOLERICK
I replaced the battery and the first time I drove the car it idled fine for about 10 minutes then the car just conked out. It turned right back on then the idle just dropped to 0 and the car turned off.
Will a bad alternator keep the car from running after it is started.
The battery is completely dead now
May 12, 2010 at 7:55 AM
  • 31,937 POSTS
Hi there,
Check the alternator charge rate and check for any current draw with the ignition off, this is a simple test for your mechanic to do.
mark (mhpautos)
May 12, 2010 at 11:15 AM
