Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Corolla
Engine
Crankshaft
Torque
Crankshaft torque settings
2005 TOYOTA COROLLA
250,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
B.LUTCHMANAN
MEMBER
Hi i am rebuilding the engine on a toyota run x 1.6 with a 4zze 587 410 engine and in need of all the torque settings for it
Dec 20, 2018 at 12:39 AM
Experienced Mechanic
Here is a video to show you how to use a torque wrench and the specs in the diagrams below:
https://youtu.be/juOClONIWeY
Images (Click to enlarge)
Aug 10, 2020 at 3:18 AM
DHAYNE
MEMBER
1 POST
what is the torque specs for crank bolts on 1992 corolla 1.6l
Dec 26, 2020 at 6:51 AM (Merged)
KHLOW2008
Connecting rod cap nuts = 36 ft.lbs. (49 N.m.)
Main bearing cap bolts = 44 ft.lbs. (60 N.m.)
For main bearing caps, tighten evenly in sequence according to diagram.
Image (Click to enlarge)
CAMERONDOBBS
MEMBER
1 POST
Currently replacing engine bearings and need to know how tight the torque has to be.
KHLOW2008
Refer to diagram.
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
