2009 Toyota Rav4 liquid drops
ONEWIDZ
  • 18 POSTS
2009 Toyota Rav4 4 cyl Four Wheel Drive
Hi, the outside temperature is 87 degree, I been running the air conditioning for hours. When I park the car in the garage and I saw there is some liquid, touched it and it is not coolant or oil, feel like water, no smells. The water is coming from a little tube on the passenger side of the car need the firewall. Could this be normal with the temperature that high and also running the ac for hour ? What do you think this liquid is ? and what is the little tube from the passenger side ?
Jun 18, 2010 at 6:26 AM
DOCFIXIT
  • 18,828 POSTS
Yes normal tube is drain for A/C evaporator. When A/C runs it pulls moisture from air ie. dehumidfies
Jun 18, 2010 at 8:22 AM
