2009 Toyota Rav4 Grinding Noise
ONEWIDZ
  • 18 POSTS
2009 Toyota Rav4 Four Wheel Drive 8000 miles
Heard grinding noise while drive, I suspect the wheel bearing is bad, but how do you determine which one ?
Jun 22, 2010 at 10:43 AM
  • 31,937 POSTS
Jack up each wheel and spin by hand, check for noise and rough feel, there should be no movement in the bearing with the wheel rocked top to bottom, also check brakes for wear as it may be a wear indicator rubbing on a rotor as well, start here.
mark (mhpautos)
Jun 22, 2010 at 11:01 AM
