2008 Toyota Rav4 Install Factory Fog Lights
35,000 MILES • 4 CYL • 2WD • AUTOMATIC
FULL METAL JACKET
I have found foctory fog lights on line. It appears that factory wiring is in place already. Where does this factory wiring end up? Do I need to choose a different location for the switch instead of the turn signal lever? What can I do so the fog lights turn off when hi-beam headlights are selected? Your help will be greatly appreciated. Steve
Nov 15, 2009 at 8:05 AM
  • 110,248 POSTS
Steve,
I believe the on off is in the multi switch on the steering column that is used to turn lights on and off. THe switch automatically turns the fog lights off when in the high beam position.
Nov 23, 2009 at 7:38 AM
