Rattling noise - rear
VALGLAD
Noises problem 4 cyl Four Wheel Drive Automatic 54000 miles
I have a strange rattling noise coming from underneath my car (rear). It only occurs when I gently accelerate and cross 40 mph (within 2-3 mph). The car is almost shaking and making this loud noise, but when I cross 40mph it disappears. Also it seems making turns contributes to it. If I accelerate fast, there is no noise. I don't recall hitting anything, so I kinda doubt it's wheelbearing.
Thanks
Nov 6, 2009 at 9:45 AM
  • 110,248 POSTS
Take a rubber mallot and tap on the exhaust system. Check to see if there is a heat shield ratteling or the inside of the catylatic converter is loose inside.
Let me know what you find.
Nov 23, 2009 at 7:18 AM
GENE G
I had the same problem. I looked under the car for another reason and found the vapor recovery canister which is made of plastic had a 1 inch diameter hole in it. Probably from a rock or something. The canister is located under the car near the drivers door. The hole caused a vacuum leak. I plugged the hole with FLEXTAPE and now there is no more shake and shudder at 35 to 45 mph.
Sep 2, 2017 at 10:05 AM
  • 55,673 POSTS
Great addition to this thread! Please feel free to help out whenever you are on the site :)
Cheers, Ken
Sep 4, 2017 at 1:20 PM
