2006 Toyota Rav4 No heat
KOTAKJI2001
Heater problem
2006 Toyota Rav4 4 cyl Four Wheel Drive Automatic
Please help and advise.
Car - 2006 Rav4 - 4 Cyc - 4WD
#1. Realized that no heat. It worked fine before.
#2. Just replaced thermostat.
#3. Little bit better than before but still no heat (lukewarm only)
#4. Air conditioner is wokring fine.
#5. Temp gauge is working fine (Indicates half way).
#6. Checked fuses and all good.
#7. Tried to bleed air out but no radiator cap for this car.
#8. Realized that the FAN is not working. However, when I turned on AC it worked fine. I checked the fuse and it was OK.
Now what do I need to do???
Oct 18, 2009 at 2:27 AM
  • 110,248 POSTS
What fan isn't working the radiator fan or the blower motor fan?
Nov 23, 2009 at 7:42 AM
