2005 Toyota Rav4 Door Locks issue using Remote
2005 TOYOTA RAV4
58,000 MILES • 4 CYL • 4WD • AUTOMATIC
TITTLE
I use remote to unloack the doors. All work fine except the Front Passenger side door lock. Sometimes it locks and unlocks and sometimes it doesn't. It's frustrating to make my pregnant wife stand outside in the cold weather till i seat in and unlock her side of door.
I click unlock for couple of times the lock struggles and closes halfway but it's not competely locked/Unlocked.
Please suggest. Thanks in Advance
Nov 2, 2010 at 7:49 AM
KHLOW2008
  • 41,814 POSTS
Hi tittle,
Either the door lock actuator is weak and failing or the linkages are stiff and requires some lubrication.
You would need to remove the door panel to check.
Nov 7, 2010 at 2:36 AM
