2004 Toyota Rav4 power loss
140,000 MILES • 4 CYL • 2WD • AUTOMATIC
LPEEK
  • 55 POSTS
car has 2 time died while driving. Lost all electrical power ,dash ligths, radio engine died. after sitting a few minutes engine restarted. alt and batt check ok. drives ok otherwise.
Sep 23, 2010 at 7:41 AM
KHLOW2008
  • 41,812 POSTS
Hi lpeek,
Intermittent power disruption are mostly caused by faulty ignition switched.
Check if the ignition switch is hot to the touch after driving for a few minutes.
When problem occurs, cycle the ignition switch on and off a few times to check if the dash indicator and other components comes on or flickers.
Sep 24, 2010 at 1:36 AM
