2003 Toyota Rav4 Power Door Lock not working on Passenger S
2003 TOYOTA RAV4
100,230 MILES • 4 CYL • 4WD • AUTOMATIC
OZAER
When attempting to lock/unlock the door(s) through the drivers side switch on the door, or the button on the key remote, the passenger door will not lock/unlock.
this problem suddenly started. Is it possible somebody tried to 'slim-jim' the door or is this a known faulty problem that can be easily fixed?
May 7, 2010 at 6:30 AM
KHLOW2008
  • 41,814 POSTS
Hi ozaer,
Thank you for the donation.
The door lock actuators do give way over time and testings can be carried out to determine if it is faulty or a wirring circuit problem.
If the actuator is bad, replacement would be ewquired.
May 7, 2010 at 10:09 AM
