Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
RAV4
Drivetrain
Transmission
Shift Solenoid
Location
Location of shift solenoid
2002 TOYOTA RAV4
PUENTE1
MEMBER
1 POST
i need to replace the shift solenoid, do i have to remove the oil pan ?
Aug 16, 2008 at 7:42 AM
Experienced Mechanic
Yes, you do need to remove the pan. here is a guide to walk you through and diagrams below to show you how on your car below:
Images (Click to enlarge)
Aug 17, 2018 at 3:45 AM
GETNET ABEBE
MEMBER
1 POST
my rav4 manufacture year 2001 have shifting problem .i discover its shifting solenoid problem were it locate on valve body ? i thanks a lot .
May 11, 2020 at 5:43 AM (Merged)
HMAC300
what is the code it may not be the solenoid it may be something else in trans causing the problem. there are 5 of them
Image (Click to enlarge)
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine has low power
