2002 Toyota Rav4
103,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOHNARGO
2002 toyota rav 4 .it acts like it shifts back and forth between 1st and 2nd gears. i changed tranny fluid and filter. now it acts the same but also seems like it is slipping. what do you think could be the problem with it.
Dec 9, 2008 at 7:18 AM
2CARPRO JACK
  • 11,533 POSTS
Is the speedo working properly? Check engine light on? Could be a solenoid or a servo, or a speed sensor. Need to have the PCM scanned for codes to see which direction to go in
Dec 9, 2008 at 7:57 AM
