2001 Toyota Rav4 window motor
LEWISANDCALLUM
Other Category problem
2001 Toyota Rav4 Engine Size unknown Four Wheel Drive Manual 95000 miles
hi, i have got a problem with my windows ,the window s are makeing a wineing noise when you put them down, they are also slow
Jan 8, 2008 at 5:06 PM
  • 31,937 POSTS
Hi there,
It sounds as if the windows are sticking in the Bailey channel, that the felted track thy run in, as a fits off, you can buy a special spray on lube for the window tracks, try that first, if that is not a help you will have to have the trim removed to inspect the regulator for alignment and ease of operation, do this before you burn out a motor.
Mark (mhpautos)
Jan 8, 2008 at 5:47 PM
