2000 Toyota Rav4
REJEANAH
2000 Toyota Rav4
my car is giving me a camshaft position sensor circuit malfunction code. the mechanic changed the camshaft and the crankshaft but i am still getting the same message and my car is still hesitating to start. what else should i try?
Jul 15, 2010 at 9:53 AM
  • 31,937 POSTS
Hi there,
Start with ensuring that the valve timing is correct, also check the sensor plugs for loose & corroded pins, do a continuity check for that circuit back to the ECU looking for high resistance.
Mark (mhpautos)
Jul 15, 2010 at 10:08 AM
