1999 Toyota Rav4 Diagnostic Code P0505
1999 TOYOTA RAV4
88,000 MILES • 4 CYL • FWD • AUTOMATIC
ONOXI
Every first start every morning, I have to keep my foot on the gas pedal for about a minute to keep it idle (if start without pressing the gas pedal the engine will die), after that it start and idle fine all day.
If I park the car for a few day, it will be very difficult to start on the very cold morning (have to crank 8-15 times). About a week ago, the check engine light came on and went away after an hour of driving. My scanner showed P0505. IAC cost about $200, I don't want to replace until I'm sure it's the problem.
Any suggestion? Thanks.
Dec 19, 2009 at 12:09 PM
Well you can check the coolant temperature sensor, cold start injector-if both okay try cleaning out the idle air control valve and see what happens.
Dec 19, 2009 at 5:18 PM
