To replace the clutch, do I need to remove the motor?
Feb 17, 2008 at 5:23 PM
TERI77SUBSHINE
MEMBER
to replace the clutch, do the motor and transmission need to be removed? If so, do the motor go up through or down? Please need help!
Feb 17, 2008 at 5:30 PM
2CARPRO JACK
✓ASE Certified Mechanic
You dont have to remove the engine to do the clutch.It hangs on an engine support and the front subframe has to be dropped out of the truck. Not really a DIY project unless you have a lift and previous experience working on cars
Feb 27, 2008 at 5:41 PM
