1998 Toyota Rav4 Window Motor Removal
1998 TOYOTA RAV4
80,000 MILES • 4 CYL • 4WD • MANUAL
CATJINX
Drivers side window motor stopped working with window in closed position. Can hear clicking sound in motor when window switch is depressed. Problem is that window must be lowered to remove bolts holding glass in place and then the regulator and the motor can be removed. But cannot get the window down. Any ideas?
Aug 13, 2010 at 8:45 AM
BLUELIGHTNIN6
  • 16,542 POSTS
just hook up a jumper wire to the big 2 wire connector 2 jumper wires actually,hooking them 1 way will make it go up the other way will make it go down
Aug 13, 2010 at 10:27 AM
