Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
RAV4
Engine
Symptoms
Stall at Idle
1998 Toyota Rav4 Dies at idle
1998 TOYOTA RAV4
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
KENBULL01
MEMBER
1 POST
Car starts and runs fine. After warm up, it will idle rough and then die, unless I increase throttle and RPMs. Cold weather conditions.
Jan 1, 2010 at 7:20 AM
Experienced Mechanic
Clean out the Idle Air Control Valve and also the EGR/PCV Valves. And test the Throttle Position Sensor and Air Flow Meter.
Jan 1, 2010 at 9:36 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine has low power
