Engine Mechanical problem
1998 Toyota Rav4 4 cyl Front Wheel Drive Manual
I recently replaced the clutch in my 98 Rav4. Ever since then, the 4WD doesn't fully disengage. There is a constant beeping unless I turn the 4WD on. When I turn corners or back up, the rear wheels feel like they're locking and the back end scoots. I'm not sure if the problem is related to the work that was done when I had the clutch replaced, but having trouble figuring out how to fix the problem. Is there any chance it's something simple? Or are there certain things I should check?
Feb 5, 2010 at 11:42 AM
