1997 Toyota Rav4 Turning signals
131,554 MILES • 4 CYL • 4WD • MANUAL
LEPATRICKSTER8790
The turn signals stopped working. I replaced the fuse and they worked for a few minutes then stopped twice. Will I have to get major repairs or can I fix it?
May 26, 2010 at 3:30 AM
BLUELIGHTNIN6
  • 16,542 POSTS
may be a faulty flasher relay, but if fuse blows when replacing it then most likely there is damaged wires at the steering column or the multi function (turn signal) switch is bad and needs replaced.
May 26, 2010 at 4:37 PM
