1997 Rav4 Clutch problems
DONNKEY
I have a 1997 Rav4 with a standard transmission. In the last couple of weeks the clutch has started to slip. I am wondering if there is a clutch fluid resevouire that may need topping up? I have looked all over the engine compartment but have not been able to locate one? The slipping only occurs when the engine is over 2000rpm, could this be anything other then the clutch assembly? Could it be the slave cylinder? or anything else?
Oct 22, 2007 at 9:07 AM
PAWO007
The clutch shares the brake fluid reservoir. Make sure the brake fluid is topped off, if it is, you likely have a worn clutch that is finally allowing it to slip when engaged.
Mar 18, 2008 at 5:40 AM
