1996 Toyota Rav4 Oil leak, timing belt
1996 TOYOTA RAV4
PMDAYO
Other Category problem
1996 Toyota Rav4 Engine Size unknown Four Wheel Drive Manual 129000 miles
I was told that I had an oil leak with my regularly scheduled oil change. I took it to my regular mechanic who said that they could take care of the gaskets but would recommend that I might want to take it to the Toyota delearship. In addition to the gasket they said I needed the time belt and battery replaced. Is this really necessary?
P.S. I donated I small amount, but it did not show that I donated. It was made under the e-mail pmdayo@yahoo.com
Feb 1, 2008 at 1:02 AM
MERLIN2021
  • 17,250 POSTS
At 129,000 if the belt hasn't been done yet, yes it is really needed! Unless you want to buy a new engine when the belt breaks, most states require 60,000 mile changes, Cal and MA require 105,000! You are past all expectations!
Feb 1, 2008 at 3:09 AM
LOSTINMARS
  • 222 POSTS
since when can a state tell you when to change your timing belt? hogwash.
i'm not saying it shouldn't be done, but that is ridiculous.
Feb 1, 2008 at 2:10 PM
MERLIN2021
  • 17,250 POSTS
Listin lost...I did not say a state tells you anything...they tell the manufacturer what they REQUIRE...look into it before you run your mouth...
Feb 1, 2008 at 10:22 PM
