2008 Toyota Prius
STEVE VOSS
2008 Toyota Prius
I tried to boost by battery but connected positive from good battery to negative on the prius. What can I do to start the car? Is there a fuse that has to be changed? Thanks (second request)
Jan 5, 2010 at 3:01 AM
THIS IS MIKE
  • 686 POSTS
You may have shorted out the battery that you tried to jump. Take a voltmeter to see if it is still making a charge. You should also check all of your fuses and try scanning your computer for any trouble codes.
Jan 6, 2010 at 8:01 AM
