2001 Toyota Prius whirring noise from engine
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
RAHALEVI
recently, when i turn on the engine it has started giving a whirring noise that continues for about 15 seconds after the gasoline engine cuts off, then turns on again for a minute or so, then off, on... each time it turns on there's a small sound like a very rapid beep of the horn.
Oct 27, 2009 at 12:10 PM
FORDRACING24
  • 65 POSTS
I'm not sure about the beep but the whirring noise can be the battery kicking on the electric fan which can be activited even with the car off and key removed to cool down the engine.
Jun 18, 2010 at 4:52 AM
