Toyota Previa 1994 150000
KKRISS
My previa's driver sider door isn't opening. It sometimes opens from the outside, but never from the inside. When I pull the lever on the inside door handle, it doesn't seem like it's connected to anything and just sticks straight out without retracting back to its original position. It closes normally, opening it is the problem. How can I resolve this? What do you think is the problem? I got it estimated and they just said it's a broken lock. Is that true? Thanks
Feb 16, 2007 at 5:25 PM
  • 75,988 POSTS
[quote:bed6b5609b="kkriss"]My previa's driver sider door isn't opening. It sometimes opens from the outside, but never from the inside. When I pull the lever on the inside door handle, it doesn't seem like it's connected to anything and just sticks straight out without retracting back to its original position. It closes normally, opening it is the problem. How can I resolve this? What do you think is the problem? I got it estimated and they just said it's a broken lock. Is that true? Thanks[/quote:bed6b5609b]
Check the child lock and could also be the weather seal sticking to the door frame. Sometimes you need to push the door out from the inside.
Feb 17, 2007 at 4:37 AM
KKRISS
[quote:0bfb3b95b0="rasmataz"]Check the child lock and could also be the weather seal sticking to the door frame. Sometimes you need to push the door out from the inside.[/quote:0bfb3b95b0]
No, driver's side door doesn't have a child lock. Nice try tho. thanks
Feb 17, 2007 at 5:50 AM
  • 75,988 POSTS
Miy 95 has one and No am not trying to pull a fast one,my purpose here is to help you.
Feb 17, 2007 at 9:03 PM
