1996 Toyota Previa Vibrations when car stopped
1996 TOYOTA PREVIA
154,000 MILES • 4 CYL • 2WD • AUTOMATIC
SSSAWYER
When I stop the car, it vibrates so much that I have to put it into neutral to stop it. I have had the transmission mounts and the motor mounts replaced, but it still vibrates.
Mar 7, 2010 at 3:21 PM
Do you have a check engine light and when was the last tune-up??
Try cleaning out the idle air control valve and EGR valve and test the throtttle position sensor and airflow meter.
Mar 7, 2010 at 4:02 PM
