1995 Toyota Previa engine will not stay running.
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
JCJONES21
I have a problem with keeping the engine running for more than two sec. I took the plugs out and checked them for cracks,gap,and any thing unusual there was nothing wrong with them.I checked for spark it was good.then I did a compretion test on each cylinder and compretion was good.when it start's it sounds good and then die as if it just ran out of gas.I just changed the fuel filter a while a go.And my injectors seem to be in good shape.don't knoe what els to check for please help.
Apr 25, 2008 at 10:57 AM
ROB2008
  • 258 POSTS
You have to check for vacuum leaks .
Apr 25, 2008 at 11:10 AM
  • 75,988 POSTS
Check your fuel pressure and comeback with the readings this is where we start.
