HOW DO i REMOVE THE SWITH WHERE i PLACE THE KEY TO START THE CAR... iGNITION REPLACEMENT
Dec 13, 2008 at 6:54 AM
✓Experienced Mechanic
Nancy, the tumbler is in the steering column. Therefore, you need to remove the steering wheel and part of the column to get to it. If the car has an airbag, I recommend having someone do it with experience so you don't accidentaly deploy the air bag.
