1992 Toyota Previa efi fuse
CHARLESFAW
Engine Mechanical problem
1992 Toyota Previa 4 cyl Two Wheel Drive Automatic
I have no power to my efi fuse. I have a good fuse.
Jun 19, 2009 at 8:14 AM
DOCFIXIT
  • 18,828 POSTS
Think EFI is on ground side. What is problem?
Jun 19, 2009 at 9:22 AM
CHARLESFAW
[quote:0ed05e903e="Docfixit"]Think EFI is on ground side. What is problem?[/quote:0ed05e903e]I have no spark. The van turns over fine.New coil, cap, rotor.Distributor turns.???
Jun 20, 2009 at 12:31 AM
DOCFIXIT
  • 18,828 POSTS
Check to see if igniter is working put test light on negative coil terminal crank does it flash?
Jun 21, 2009 at 4:33 AM
