1991 Toyota Previa Swapping wheels/tires with a 1989 Toyota
1991 TOYOTA PREVIA
194,000 MILES • 4 CYL • AWD • MANUAL
RJDJIYCE
I would like to know if I could safely swap my wheels and tires of my 1989 Toyota Camry with 185/70 R14 size tires (with 13k miles of wear) with my 1991 Toyota Previa with P205/75 R14 size tires (with 43k miles of wear)? Thanks.
Bob
Oct 10, 2009 at 6:21 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Hi Bob,
Honestly, you would have to check it by taking one and trying it. I believe the Lug Pattern is the same just not sure if the wider 205 will fit. You would be best off doing it on the front and turning the wheels and check the clearance.
Oct 10, 2009 at 6:27 AM
