1991 Toyota Previa starting is late
180,000 MILES • 4 CYL • 2WD • MANUAL
HAMED OMAR
dear sir
my car it takes time to start even the candles and the wires are new.
in the same time the car some times it shakes when it is in speed of gear 1 and 2 .
best regards
Aug 17, 2010 at 7:30 PM
  • 75,988 POSTS
Test the coolant temperature sesor, throttle posiiton sensor, MAF sensor, vehicle speed sensor and clean out the idle air control valve and also check fuel pressure
Aug 17, 2010 at 10:14 PM
