1991 Toyota Previa Car Engine Misfires Poor Running - Tune
1991 TOYOTA PREVIA
220,000 MILES • 4 CYL • 2WD • AUTOMATIC
DBONNELL1972
It is in pretty good shape for it's age, but it has been stored for many years. It appears to intermittently misfire only when the following conditions are met: 1. it is hot from idling for long periods, stop and go driving, or driving in hilly terrain and 2. when pushed for acceleration. It has fresh oil, and I just put in fresh NGK platinum plugs, and recently ran Seafoam through the fuel system. Cap and rotor look clean, dry, and intact. No CK ENG light. Special note: the coil on the Previas is mounted against the firewall near the exhaust manifold. Can heat be affecting the coil, and how can I diagnose the coil for an intermittent problem?
Sep 8, 2008 at 4:38 AM
  • 110,240 POSTS
did you replace the ignition wires? Also, I would recomend replacing the cap and rotor too.
Sep 1, 2009 at 3:13 AM
