1991 Toyota Previa AC Switch located above the Radio.
22,500 MILES • 4 CYL • 2WD • AUTOMATIC
CARLOS ESTANISLAO
The light on the switch when you push it is off. It is suppose to be lit. Do I have to replace it so that the ac will cool or it has nothing to so with the freon cooling the inside car? If I have to replace it how much would be the switch replacement.?
Aug 23, 2010 at 1:59 PM
BLUELIGHTNIN6
  • 16,542 POSTS
is a/c still working properly? most likely switch is bad which will not let a/c work, if that's the case than switch must be replaced. it may also just be a bad fuse though so check fuses first.
Aug 23, 2010 at 2:04 PM
