1991 Toyota Previa
1991 TOYOTA PREVIA
HAMED OMAR
Warranty problem
1991 Toyota Previa 4 cyl Two Wheel Drive Manual
oil change light and battery light are on while the battry is new and the oil is new also.
b.regards
Jul 17, 2010 at 8:29 PM
Battery light coming On it means there's a problem within the charging system try by passing the regulator by grounding out the regulator if the light goes out replace the voltage regulator if not replace the alternator
Oil light try removing the EFI fuse for 10secs and see what happens
Jul 17, 2010 at 8:59 PM
