leaking from my radiator?
170,000 MILES • 4 CYL • 4WD • AUTOMATIC
PREZZIE
I see some form of fluid (oil) apparently leaking from my radiator. i was advised that it is possibly a leak in the cooling system as some radiators have an oil component. Is that true.
May 24, 2009 at 6:11 PM
SQM
  • 6,383 POSTS
Typically a radiator will have cooler lines for the transmission. So you can see transmission fluid leaking out of a radiator but not engine oil.
https://www.2carpros.com/articles/how-a-radiator-works
If you have oil in coolant, that is a sign of a blown head gasket.
Check your oil to see what color it is. If it is milky white they you have coolant mixed in the engine oil.
There is a test you can do to see if you have a blown head gasket. That test checks for combustion gases in the coolant. When a head gasket is blown you will have combustion gas leak into the coolant from the engine.
Here is a helpful video:
https://youtu.be/5zpNjYmmiYY
Aug 24, 2021 at 1:24 PM
