My truck is miss-firing at about 4500 to 5000 RPMs. It usually does it when I go into passing gear. Most of the miss-fires are in 2 but also in 5, 6, 8. I have changed the mass air flow sensor, O2 sensors in bank one, spark plugs and wires, and cleaned the throttle body but I am still having the same problem. The truck runs great at normal driving with no miss fires. I am also having trouble trying to perk the coolant system. I recently replaced the coolant flange on the right side of the motor because it was cracked and leaking. After I replaced the part and put everything back together, I attempted to perk the coolant system. I put the heat on high and filled the reservoir and waited for the thermostat to kick on. I sat in the car and after about 5 minutes I could feel the hot air coming out of the vents, but moments after that cold air began flowing and the car would just continue to overheat.
SPONSORED LINKS
Sunday, April 15th, 2007 AT 2:05 AM
