1991 Toyota Pickup Slows Down
GREG OVERLOCK
We have a 1991 Toyota pickup with 123000 miles.while driving along the truck will slow down rpms'drop like it has no gas.We have changed gas filters multipul times and it still happens,but not enough to get a good test on fuel pump.Do you know of any other causes.
Jun 17, 2006 at 11:06 AM
SYNCRAIT
  • 235 POSTS
if its not sputtering i bet its going to be a weak fuel pump... does it at any time sputter with hard acceleration or high rpms?
Jun 17, 2006 at 11:44 AM
GREG OVERLOCK
It doesn't sputter.It just slows down like its going to stall,then seams to come out of it.
Jun 17, 2006 at 11:22 PM
GREG OVERLOCK
It seams to do it when cold and come out of it when it warms up.
Jun 24, 2006 at 12:40 AM
SYNCRAIT
  • 235 POSTS
im going to bet that its the fuel pump just starting to go.... what i think is happening is the pump is starting to seize up but since its still rolling it might get jarred because of a bump or whatever and kick back in.....if it is the pump it will get progressivly worse untill it kicks for good.... you might also check and make sure none of your spark plug wires are touching the engine as it may also be a short issue instead of lack of fuel it might be spark also.....good luck :)
Jun 24, 2006 at 1:02 AM
Suggested Repair
Suspect a weak fuel pump that is beginning to fail and may worsen. Also inspect the spark plug wires so none are touching the engine and shorting spark.
Conversation Summary
A 1991 Toyota Pickup with 123,000 miles slows and the RPMs drop as if it is running out of fuel, without sputtering. Fuel filters were replaced more than once. The problem is more noticeable when cold and eases as the engine warms. The expert suspects a fuel pump starting to fail and also suggests checking that spark plug wires are not touching the engine.
