I have a 1994 4x4 Toyota Ext.Cab Pickup, 3L V6, Standard Trans.
After engine is warm, sometimes the engine "lopes" and kind of "deisels" at idle & almost stalls. At mid range RPM, it runs a it irradically and is less noticable throughout the power ban but is still miss firing a bit.
It seems to be only from time to time and not all the time.
If I shut the engine off at the time of rough idle, it will not start no matter what, until engine is cooled off or about 1-2 hours.
At first I thought the feul pump was faulty beause I had gone through a few after market fuel pumps in the past that my truck did not like. The one I recently replaced seemed OK but a Toyota mechanic said that it may be due to a boarder line pressure and so I dropped $460.00 on a new one and replaced it and the feul filter.
Still having the problem and it seems worse with certain brands and Octane rated gas.
I looked for vacuum leak but could not find one anywhere. I did notice however, that there was a louder than normal tapping noise by the fuel injector rail( I think it is the pressure ragulator. Looks like a small metal disk with vacuum hose and contains a diaphram)
Mar 19, 2007 at 7:11 AM
