toyota PU possibly running hot
1993TOYOTAPU
Hello, my problem is that when i first start my 1993 Toyota PU 4 cyl (22re w/165000) the temperature gauge almost goes into the red after about 7 minutes. Then it goes down about halfway and up again though not as much. It does this a little more and finally settles just below half. I have owned this truck for 7 yrs in the same location and it used to not do this. Just changed the coolant and put in a new thermostat and plugs (old ones looked ok if a little white) but nothing changed. I would like to check the actual temperature of the engine before the thermostat seems to open or just when it opens and have heard of putting some sort of temperature gauge in the radiator (where can I get one?) or can I use a temperature gun? Any tips would be appreciated -ThankYou- Mark
Apr 8, 2007 at 10:46 AM
  • 75,988 POSTS
Could be a bad new Stat-take it back out and run the engine without it and observe the gauge-don't worry what the computer is thinking and doing.
Condition of R/Cap is it okay? the oil and coolant looks good-no milky color and oil streak on the coolant
Apr 8, 2007 at 11:04 AM
1993TOYOTAPU
thanks, I will check thermostat. Does anyone know if these temperature gauges fail? Thanks--mark
Apr 9, 2007 at 5:25 AM
