1993 Toyota 4Runner No Spark
808_GURL
Hi.. My friend has a 93 toyota 4 runner that he blew the engine on... it had 131,000 miles and a 3.0 V6, which he replaced with a 1989 toyota pickup 3.0 v6 engine... the problem that he has is that there is no spark..the engine turns over and the timing is set, but it just wont start.... it has a new distributor cap, rotor, wires and plugs... but we have no idea where to start and what could possibly be wrong??? Any help would greatly appreciated...
Feb 7, 2007 at 6:01 PM
BACKYARDMECHANIC
  • 337 POSTS
I'am assuming that the new motor is the same, not only in size but things like the distributor, fuel system, wiring harness etc etc. You Started with the basics and checked for fuel and spark. First check power to the primary side of the coil. If you dohave power then you have a bad coil cap rotor or wires. If You have no power to the primary side of the coil then there is a problem with the iginition module, crank sensor or the wiring harness to it. If you have both then check that the timing is correct. I have one question; did you see the new motor running before you installed it? Good luck
Feb 8, 2007 at 12:50 AM
808_GURL
we thought that it could possibly be the coil but we arent sure how to go about checking if its bad..the only thing that didnt match up on the wiring harness is the wiring to the sensor on the top of the engine below the EFI housing, he just replaced the harness with the one from the 89 engine...not sure if that makes a difference.... the guy that we got the motor from said that it was running before we got it...
thanks for your help, its greatly appreciated....
Feb 8, 2007 at 8:35 AM
Suggested Repair
Check for power at the coil primary. If power is present, test the coil, cap, rotor, and wires. If not, inspect the ignition module, crank sensor, and wiring harness, including the sensor circuit swapped from the 1989 engine. Confirm timing and that the donor engine ran before installation.
Conversation Summary
A 1993 Toyota 4Runner with a 3.0 V6 had its blown engine replaced with a 1989 Toyota Pickup 3.0 V6. It cranks with timing set and new cap, rotor, wires, and plugs, but has no spark. The expert advised checking coil primary power, then the coil and ignition parts or the ignition module, crank sensor, and harness. The owner noted a mismatched sensor harness was replaced with the 1989 harness and was told the donor engine had been running.
