The disributor uses ported vacuum meaning the vacuum should come from above the throttle plate-my guess is, you are using intake manifold vacuum ( full vacuum )That's what causing it to advance when plugged back in.
When you pull the throttle back this is where you get the vacuum advance needed.
HTH Good Luck
SPONSORED LINKS
Sunday, March 18th, 2007 AT 8:38 AM
