1993 Toyota Pickup Temp Gauge Fluctuates
HUGHDALEHARRIS
I have a Toyota Pickup 1993 3.0L 4WD 270,000KM manual transmission.
I recently flushed the radiator because the coolant was looking a little brown. After I flushed the rad, the temperature gauge fluctuates all over the place, and unpredictably too. Before the flush, the temp gauge went to a certain temp and stuck there. Now, it'll rise when the engine is working harder but then fall all of a sudden, with the engine still working hard. generally it's rising and falling unpredictably. I topped up the reservoir, and tried to expel all of the air. What is going on? Is there still air in the system? Did flushing it dislodge some sediment that is making the thermostat falter? is it the water pump?
Jun 11, 2007 at 5:31 AM
  • 75,988 POSTS
[quote:2aa82abd54="hughdaleharris"]I have a Toyota Pickup 1993 3.0L 4WD 270,000KM manual transmission.
I recently flushed the radiator because the coolant was looking a little brown. After I flushed the rad, the temperature gauge fluctuates all over the place, and unpredictably too. Before the flush, the temp gauge went to a certain temp and stuck there. Now, it'll rise when the engine is working harder but then fall all of a sudden, with the engine still working hard. generally it's rising and falling unpredictably. I topped up the reservoir, and tried to expel all of the air. What is going on? Is there still air in the system? Did flushing it dislodge some sediment that is making the thermostat falter? is it the water pump?[/quote:2aa82abd54]
Cheap fix change the Stat,refill and bleed it.
Jun 11, 2007 at 10:40 AM
HUGHDALEHARRIS
I went back and discovered that it was just the coolant that was low.
after i flushed the rad, i didn't wait long enough (i should have left it overnight) to let the engine cool then top up the coolant level. Because the engine was still a bit warm, the level looked good. once it cooled completely, the coolant level went down and just needed topping up. I just needed to be more patient! easy fix this time! :D
Jun 12, 2007 at 2:18 AM
Suggested Repair
After a complete cool-down, top up the coolant and bleed any remaining air. If the gauge still fluctuates, replace the thermostat, refill, and bleed the system.
Conversation Summary
A 1993 Toyota Pickup developed an erratic temperature gauge after a radiator flush. An expert suggested replacing the thermostat, refilling, and bleeding the cooling system. The owner later found the coolant level had dropped once the engine fully cooled and that topping it up resolved the fluctuation.
