1994 Toyota Pickup will not heat up
130,000 MILES • 6 CYL • 4WD • MANUAL
94'04'TOYOTA
New radiator,thermostate,hoses,timing belt,waterpump was done when the weather was warm. The truck seemed to be fine but not driven much. When the weather got colder(30s and 40s) The temperature gauge only comes up 3/4 or so and the idel stays up around 1400 to 1700. Gas millage is poor. If you set in trafic it will nearly come up to temperature but then drops when your moving. It was thought the thermostate was in backwards or bad, so that was checked and replaced. Is there anything else I could check. My buddy has a SNAP ON computer so I had him plug it in but there still wasnt anything that jumped out at us wrong.
Jan 26, 2008 at 1:34 PM
  • 75,988 POSTS
The thermostat's job is to control engine temperature-double check it make sure if it has a jiggle valve position it correctly or replace it again.
Your idle is way too high-do something with it-that's where your gas is going to.
Jan 26, 2008 at 5:09 PM
