I have a 1996 Toyota Tacome V6, 3.6? maybe the only one they put in that year, 5 speed extended cab 4X4 SR5 with 42000 miles. The truck just recently started runnubg bery poorly. backfiring in the engine compartment and loosing power. Consequently about the same time the speedodometer qiut working. I purchased a code scanner and it gave me a code of 0500 which shows as a (VSS) Vehicle Speed Sensor. after an exhasutive search I was unavble to locate a VSS on the vehicle. Everyone I talk to say it has an electronic speedodometer. The sppedodometer cable was easly located after I stopped looking for an electronic sensor. The plastic gear was damaged but I donot see how a mechanical part could cause the VSS code or teh rough running of the vehicle. I have reset teh check engine light and it continues to come on and shows the VSS. Any hael would be greatly appreciated Thanks Tim
Nov 12, 2007 at 9:24 AM
