1994 Toyota Pickup High Beams Out
GUINNESS4METOO
Hello. My highbeams have recently gone out. My low beams work just fine. When I push the switch foward, (to turn them on), they dont come on and when you pull them back ( like you are flashing someone in front of you), they come on. Any suggestions on what would be causing this problem would be a great help. I have a 1994 Toyota Pickup 4-cylinder 2WD.
Mar 21, 2007 at 11:06 AM
SERVICE WRITER
  • 9,123 POSTS
So you flash people huh?? :shock:
Sounds like the switch is bad.
Mar 21, 2007 at 11:19 AM
  • 75,988 POSTS
Sounds like this problem is nailed to the T
The switch grounds it to comlete its circuitry-No ground=No light and again it might be a relay going south of border to Belize- I love that secret place. Go there and you'll know what am talking about. Women!!!!! and TQ do mix together.
Mar 21, 2007 at 2:19 PM
Suggested Repair
Test and likely replace the headlight dimmer switch. Also check the high-beam relay and the switch ground circuit, since the flash function works but the high beams will not stay on.
Conversation Summary
The owner of a 1994 Toyota Pickup reports that the low beams work, but the high beams do not stay on when the switch is pushed forward. Pulling the switch back to flash the high beams does turn them on. Experts suggest a faulty dimmer switch that may not be grounding the circuit, and possibly a failing high-beam relay.
