Clutch problems on 1997 Tacoma
ZIPMN909
1997 Toyota Tacoma, 3.4L V6, 4WD, 135K miles. New clutch installed by dealer appx 14 months ago at 115K miles.
Around 3 months ago the clutch pedal began to not come all the way back up when you released it. It got progressively worse. I changed out the slave cylinder. This seemed to make it better for a couple of days, then the problem returned so I changed out the master cylinder. This appeared to fix the problem until a week ago. Now the clutch is not fully disengaging from the pressure plate when it is pushed in. I can't fiind a leak and the fluid level doesn't appear to be changing. Bleeding does not seem to help. Both the slave and master cylinders I installed were after market parts. Any idea how I can track the problem down and fix it for good?
Thanks
Oct 16, 2007 at 4:12 PM
2CARPRO JACK
  • 11,533 POSTS
Even with a hydraulic system there needs to be a little free play in the pedal. Adjust the rod from pedal to master so that there is a little play( about 1-2 inches) in the pedal before it begins to move the piston in the master
Oct 17, 2007 at 1:54 AM
ZIPMN909
[quote:89c8f7a550="2CarPro Jack"]Even with a hydraulic system there needs to be a little free play in the pedal. Adjust the rod from pedal to master so that there is a little play( about 1-2 inches) in the pedal before it begins to move the piston in the master[/quote:89c8f7a550]
With the clutch pedal all the way in, the clutch is not fully separating from the pressure plate.
Oct 17, 2007 at 11:29 AM
2CARPRO JACK
  • 11,533 POSTS
Is there free play or not?
Oct 18, 2007 at 5:11 AM
