I have a 1993 toyota T100 v6 4X4 manual trans. I just changed my clutch, slave and master cylnder. I also bled the system. I started my engine and tried to put it into gear but the gear would not engage. no gears would engage. But when i start the engine in gear and start to release the cluth, i can feel it grabbing and i'm pretty sure i can drive off, however i can not shift it into 2nd. My clutch pedal seems way loose as if there was no pressure going to the system.
Could it be possible i have a defective part somewhere?
Thanks.
Thanks.
Aug 2, 2007 at 11:37 AM
