1979 Toyota Pickup High CO Emissions
KENOFAZ
I have a 1979 Toyota 4x4 pickup with the 20R four cyl engine. I can't pass emissions. I replaced plugs, rotor, cap. wires, pcv valve, and carburetor. I still couldn't pass. I took it to a repair place and they got it as close to passing as they could. They said it was borderline. It failed with about 20% more than allowed on the CO at cruising speed. It passed CO at idle easily, as well as passed HC easily at cruise and idle. The repair place said the only other thing they could do would be to rejet the carb and it would cost me $200 and they couldn't guarantee that it would improve or that they could find leaner jets to fit.
I am wondering if I could instal a universal fit (about $100) catalitic converter and improve my CO by about 20% at cruise speed. Or any other ideas?
Thanks for any help.
May 8, 2007 at 4:57 PM
  • 75,988 POSTS
[quote:bc579a1ea8="KenOfAZ"]I have a 1979 Toyota 4x4 pickup with the 20R four cyl engine. I can't pass emissions. I replaced plugs, rotor, cap. wires, pcv valve, and carburetor. I still couldn't pass. I took it to a repair place and they got it as close to passing as they could. They said it was borderline. It failed with about 20% more than allowed on the CO at cruising speed. It passed CO at idle easily, as well as passed HC easily at cruise and idle. The repair place said the only other thing they could do would be to rejet the carb and it would cost me $200 and they couldn't guarantee that it would improve or that they could find leaner jets to fit.
Thanks for any help.[/quote:bc579a1ea8]
Could be an air pump or diverter problem and catalytic converter.
May 9, 2007 at 10:07 AM
KENOFAZ
[quote:3a9abce5f7="rasmataz"][/quote:3a9abce5f7]
Could be an air pump or diverter problem and catalytic converter.[/quote]
The repair place tested the air pump and said it was working. I don't know what a diverter is. I would think they tested that too. It does NOT have a factory catalitic converter. I was thinking that if I added one, it would reduce the CO significantly. Am I right? Or would it barely make a difference in CO? I am thinking I could add a catalitic converter for half of what they want to rejet the carb.
Thanks.
May 9, 2007 at 2:59 PM
Suggested Repair
Check the air injection system, especially the diverter valve, and consider adding a catalytic converter. The air pump was already tested and reported working, and the truck has no factory converter.
Conversation Summary
A 1979 Toyota Pickup with a 20R engine fails emissions with cruise CO about 20% over the limit, while idle CO and HC at idle and cruise pass. Plugs, cap, rotor, wires, PCV valve, and carburetor were replaced, and a shop said rejetting might help but could not guarantee it. The expert suggested an air pump, diverter, or catalytic converter problem. The owner said the air pump tested good and the truck has no factory converter, and asked whether adding one would reduce cruise CO.
