97 Tacoma engine miss
MAGICMAN53
toyota tacoma extended cab, 3.4l v-5 engine, 158,000 miles on it. Initially my check engine light came on and it said #1 cylinder misfire so I replaced the 3 ignition wires, changed the plugs. it seem to run better but it bogs down when I mash down on the accelerator. if i gradual apply the gas in a smooth manner it won't do this. this even happens on the interstate w/cruise control on and you go up a long grade, it will miss out.
Oct 3, 2007 at 9:58 AM
BUZZSAW
  • 1,198 POSTS
[quote:74f73e786f="magicman53"]toyota tacoma extended cab, 3.4l v-5 engine, 158,000 miles on it. Initially my check engine light came on and it said #1 cylinder misfire so I replaced the 3 ignition wires, changed the plugs. it seem to run better but it bogs down when I mash down on the accelerator. if i gradual apply the gas in a smooth manner it won't do this. this even happens on the interstate w/cruise control on and you go up a long grade, it will miss out.[/quote:74f73e786f]
try coil pack for #1 cylinder
Oct 5, 2007 at 5:52 AM
SERVICE WRITER
  • 9,123 POSTS
"Try a coil pack?" Is that the dealer diagnosing you talk about? :roll:
Oct 10, 2007 at 9:04 AM
