89 Toyota Truck 3L engine
OLDGURU
I recently bought a 89 toyota truck with the V6 engine. It has a "ticking" sound that sounds to me like valve lifter noise but someone suggested it may be the injectors. Is noisy lifters common with this engine and if so what is the best cure for it? Is it a issue that can cause problems or is it more of a bother?
Thanks Vic
Mar 10, 2007 at 12:20 AM
  • 75,988 POSTS
[quote:cc98a9d939="oldguru"]I recently bought a 89 toyota truck with the V6 engine. It has a "ticking" sound that sounds to me like valve lifter noise but someone suggested it may be the injectors. Is noisy lifters common with this engine and if so what is the best cure for it? Is it a issue that can cause problems or is it more of a bother?
Thanks Vic[/quote:cc98a9d939]
Try an engine flush-don't work could be a leakdown problem with the lifters or needs a valve adjustment.
Mar 11, 2007 at 9:24 AM
